Hi All. I need to remove the pump from my Bosch Classix 1400 Express. It sounds like something is trapped insde the pump and I can’t unscrew the pump cap (only turns a small amount then jams). Before I attack it, does anyone have any hints or tips for getting at the pump and removing it?
Many thanks
Thanks helo. Turned out quite simple in the end. The pump made a fearful noise, and as I said, I couldn’t get the cap to unscrew. After taking the pump off and shaking it a bit the cover cap did unscrew. Strangly there didn’t seem to be anything obvious causing a problem and the impeller rotated freely. Tested the pump and it seemed to work ok so put it all back together and it’s working fine. Result!
