Hi, our dishwasher has developed the following fault – at the end of the wash cycle the pump will continue to run until switched off. When the M/C is switched on again, the pump will run but the cycle will not start.
Tipping the M/C back by 45 degrees empties some water onto the floor and the M/C will run the full cycle correctly.
I have removed and cleaned the filters and a run a cleaner cycle. However after a week the fault repeats. It would suggest a leak into the overflow?
Any ideas please?
Rgds
Ian
