Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › BOSCH Classixx slimline Maxx freedom performance
- This topic has 5 replies, 3 voices, and was last updated 13 years, 2 months ago by
corbett891.
February 2, 2013 at 10:44 pm #73923
corbett891
ParticipantHi all,
I have the above dishwasher.
Just moved house
Plumbed it in and set it to do a normal 65 wash.
Started okay.
Came back later on about 8 hours and the rinse aid and salt lights are lit as is the normal 65 wash button. Dishes inside are clean, all be it still a bit wet.
Opened up the machine and there is no water inside and I can here what sounds like the drain operating from the centre drain valve.
I’ve tried turning the machine on and off, and pressing in the two opposite end buttons to reset the machine all that does is light up the end light but the rinse aid and salt light are still lit and the noise from the drain area is still ongoing.
If I turn the machine off and on, the end light goes of and I can press any one of the 4 program’s, normal, Eco, quick and Pre rinse.However the rinse aid and salt lights stay lit, I can still hear what appears to be the drain operating but none of the program’s start and no water is entering the main body.
All help and advice is / would be welcome,
Many thanks,
John
February 2, 2013 at 10:53 pm #389314Allsorts
ParticipantRe: BOSCH Classixx slimline Maxx freedom performance
Could be that during your move you have inadvertently caused a spillage in the base and tripped the flood protection.
Switch off, drain away or soak up the water and reset
February 3, 2013 at 12:04 am #389315corbett891
Where would the water be to drain, as there is none inside the machine dish compartment which I can see.
Many thanks,
John
February 3, 2013 at 8:28 am #389316Allsorts
Switch off and unplug the machine, take off the panel underneath the door and if there is any water you should be able to see it there.
February 3, 2013 at 8:08 pm #389317corbett891
Still not working, I am afraid, if I tilt the machine at a 45 degree angle after a cycle finishes loads of water dains out a hole on the back centre floor of the dishwasher,
Anybody have any ideas why?
February 3, 2013 at 8:29 pm #389318iadom
ModeratorRe: BOSCH Classixx slimline Maxx freedom performance
You have an internal leak that needs isolating and fixing.
