Bosch Classixx tumble dryer not heating up
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch Classixx tumble dryer not heating up
  • #90461
    teamholmes18
    Hi there.
    I have a Bisch Classixx vented tumble dryer that has stopped heating up.
    In the past I have taken the back off, pressed the red button on the heater to reset it and its worked. This time, the button won’t press, which is suggesting to me that it has tripped. Is there a way of testing the heater to see if its finally given up the ghost?
    I have got my multimeter and have checked continuity across both the upper and lower thermostats, and both are beeping – so im assuming they are ok. I have taken the hose out and looked for any blockages which there aren’t.
    I have put my meter across the other 2 connectors between the thermostats which I believe will be the heater terminals and there is continuity between those. Is that pointing to the heater finally gone and will an eBay replacement suffice?
    Thanks in advance
    #444885
    kaibart
    Re: Bosch Classixx tumble dryer not heating up
    Hi model number may help inside the door the enr number
    #444886
    teamholmes18
    Hi there.
    Thankyou for your response. The model number is WTA4007/GB/01.
    Many thanks
    #444887
    kaibart
    You say you have continuity through the 2 thermostats this should be 0.5-1ohm and if you are checked the heater you should get a higher reading there is a front thermal limiter on the dryer to situated at the front somewhere and you should also have continuity through that as well if all have continuity it would suggest the timer has faild
    #444888
    teamholmes18
    Thanks Kalibart.
    As the tumble dryer is tucked away it was a bit of a task to get behind it and look at my multimeter, so I didn’t check the ohms readings, I just listened for the continuity beep. I don’t have continuity between the two terminals of the heater element, I didn’t get a beep. Should there be continuity between the two terminals of the heater element? (Im assuming that its the 2 terminals of the heater element. They are around central on the back of the tumble dryer and between the thermostats.
    #444889
    teamholmes18
    I have got the dryer out and done some more digging…..
    I have exposed the heater element, and have tested continuity. I have continuity on outer casing of the element. I don’t have continuity on the terminals of the element. I have tried to upload pictures of what I mean but they are too big so will describe as best I can.
    As the element passing through the metal framing, the terminals where the 2 plugs plug onto – they do not have continuity. If i put my meter onto the element side of the framing then I do have continuity across the outer casing.. so is there an inner working to the element which could have broken down?
    #444890
    kaibart
    Hi if you visit http://www.bosch-home.co.uk/store/spare you can enter the model number and it will show you where the element is 😉
    #444891
    teamholmes18
    Hi, Thanks
    Ive exposed the element.. and have found that there is no continuity at the terminals… there is continuity on the body of the element… but at the terminal there is none, which is why i am wondering if the element has an inner core which may have broken resulting in there being no continuity at the terminals
    #444892
    The heating element (part no: 00498607) needs replacing. Very common failing.
    #444893
    teamholmes18
    Thankyou Martin.. !! Does what I describe make sense? The outer casing seems to have continuity but when I go to the terminals there is no continuity which I think would suggest that the inner core has failed?
    #444894
    Yes
    #444895
    teamholmes18
    wonderful..!! while the back is off… is there anything else I should replace as a service ? I have found a collection of fluff in there which I have removed which showed signs of burn marks… so Ive cleaned that out… is the belt easily replaceable or worth doing while I have the back off, or the bearings?
