Re: Bosch Classixx WFL 2463 Drum won’t turn at all
DaveH53 wrote:Hi Martin
That seems to be the problem thanks. 2 are broken but not sure how to fix plus not sure I know which is which because all the same colour!
David
You can buy a complete wiring lead that goes from the motor to the PCB direct from Bosch’s own spares website. As to which wire goes where? Then look at the connector block at the PCB end as they are connected the same (e.g 1 to 1, 2 to 2 and so on)……easy! 😀 I always replace the complete lead by the way, much better fix.
