Bosch Classixx WTE84106GB container light on
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch Classixx WTE84106GB container light on
  • #99001
    Tally100
    I have a Bosch Classixx WTE84106GB that the container light comes on and stops drying, its plumbed into the sink so container not used , cleaned the filters which wasn’t dirty , made sure pipe wasn’t kinked. anybody got an idea what the problem could be. Its less than 2 years old and hasn’t been used much
    #474652
    the container on light is sensed by a float or electrodes in the pump chamber
    have had these chambers block up
    to save you taking it apart, if you look where the condensor comes out there is a hatch in the floor. its a bit tricky but if you remove this you can see if the pump reservoir is full or not
    could be a blocked pump not pumping out the water, without the draw in you cant be certain any water is coming out
    Tally100
    Hi Dave I managed to get the lid off the hidden compartment and there is water in it, it doesn’t seem to be blocked with anything else.
    thanks
    #474654
    if that compartment is quite full then the pump is not working or blocked
    was there any lint in there ?
    its a bit of a pig to get at the pump as you have to remove the left side of the dryer to access and clean it out
    Tally100
    I found out I had extended warranty and the pump has been replaced. Thanks
    #474656
    Tally100
    Just used the dryer and it stopped with the container light flashing , different from before pressed start and it started ok
