Bosch Classixx1200 lights flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Classixx1200 lights flashing
  • #78634
    snowhite
    Bosch WAE2416SGB/12 machine has 3 of spin lights flashing continuously. They are 1,3,5 (from top). No light on Start button. It won’t do anything. Any clues as to what may be wrong please?
    #406371
    Re: Bosch Classixx1200 lights flashing
    Motor problems, usually the brushes need checking out.
    #406372
    snowhite
    thanks Martin, I’ll check this out first
    #406373
    snowhite
    I’ve replaced the brushes, but still the same fault. I guess the motor must be kaput?
    #406374
    snowhite wrote:I’ve replaced the brushes, but still the same fault. I guess the motor must be kaput?
    It needs resetting. Turn selector dial to the 6 o’clock position, turn on, touch and hold the spin button whilst turning dial to the 7 o’clock position. Release spin button. Turn dial to off and power off. That (hopefully) should reset it.
    #406375
    snowhite
    that seems to have done the trick…..it certainly spins now.
    I’ll let the other half give it a trial tomorrow!
    thanks Martin.
