Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Classixx6 1400 error F21
- This topic has 17 replies, 4 voices, and was last updated 11 years, 11 months ago by
W31rdy.
April 25, 2014 at 3:02 pm #80446
W31rdy
ParticipantGreetings,
Got Error F21 on the machine this morning. The Bosch website states Either Control Board or Motor! But I have read else where it could be bushes?
I have tried all the setting and holding buttons reset, it just says F21 and does nothing else!
So, how do I actually tell whats the faulty part from the three possible options? Once ID’d where can I get cheap replacement parts from?
ADVthanks
W31rdy
April 25, 2014 at 3:28 pm #412870Martin
ParticipantRe: Bosch Classixx6 1400 error F21
The motor brushes need replacing to sort. Simple fix, go for it!
April 25, 2014 at 3:43 pm #412871W31rdy
Martin wrote:The motor brushes need replacing to sort. Simple fix, go for it!
and cheap too 🙂 THANKS good place to start 😉
April 28, 2014 at 1:38 pm #412872W31rdy
Brushes changed! Still get the error!
Have I just wasted £20? and an hours work?
April 28, 2014 at 1:42 pm #412873Martin
Probably will now only need the programme resetting. What is the FULL model number of this machine anyway?
April 28, 2014 at 4:21 pm #412874W31rdy
I was thinking could the brushes be upseide down or not fully seated? Will get the ful number for you now 🙂 THANKS in Advance for your help!
April 28, 2014 at 4:22 pm #412875W31rdy
WAE28363GB
its the 1400 Model about 5/6 years old if that helps 🙂
April 28, 2014 at 4:30 pm #412876Martin
W31rdy wrote:WAE28363GB
Not the full number but hey. 🙁
Press and hold the spin button whilst turning the dial to the 6o’clock position. Then turn one position clockwise and release the spin button. Reset the dial to off.
April 28, 2014 at 5:08 pm #412877W31rdy
Martin wrote:
W31rdy wrote:
WAE28363GBNot the full number but hey. 🙁
ok, WAE28363GB/02 FD8711603100
Still does nothing but flash F21 at me 🙁
So could be brushes be in wrong? I have the bevel pointing down towards the middle, could they no be seated properly?
April 28, 2014 at 5:19 pm #412878Martin
No!
Disconnect the motor plug then do the reset procedure again. Then plug the motor back in. Try it then.
April 28, 2014 at 5:34 pm #412879W31rdy
Martin wrote:No!
will do thanks 🙂
April 28, 2014 at 5:49 pm #412880W31rdy
Ok, disconnected the multi block from motor, did reset as you said, plugged back in, redid reset as you said! Still nothing 🙁
April 28, 2014 at 5:54 pm #412881Martin
Time to check the continuity of the motor windings then. The motor’s TOC may gave gone O/C?
April 28, 2014 at 6:06 pm #412882W31rdy
TOC? O/C Open Circuit?
Best way of checking the windings is to remove the motor I guess?
April 28, 2014 at 6:12 pm #412883Martin
W31rdy wrote:TOC? O/C Open Circuit?
We assume a basic grasp of electrical knowledge so, and with respect, I’ll leave you with that simple conundrum to figure. 😉
