Bosch CMA583MS0B/1 Microwave/Combi Oven Tripping & No M/Wave Heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch CMA583MS0B/1 Microwave/Combi Oven Tripping & No M/Wave Heat
Viewing 15 posts - 1 through 15 (of 15 total)
  • #102545
    jontymox
    Good afternoon all,
    The above microwave does not heat, and is randomly tripping.
    I carried out several tests at my customer’s prior to bringing the unit back to my workshop, as I was/am struggling to locate the cause/s of the above.
    I’ve electrically and visually tested the transformer, and magnetron, along with the high voltage capacitor and diode.
    The above all appear fine.
    The power module appears to be suspect, as the voltage to the transformer is very low, but thought I’d ask on here if I should be testing anything else, before ordering a new board.
    jonty
    #489366
    ok first off its an isolation transformer and on side of secondary is to earth anyway so it has to be before transfomer
    i would disconnect one of the wires to the transformer primary so you can play without the problems of high voltage
    most likely causes of this is element and not microwave side
    jontymox
    Does anyone have a wiring diagram for the above that could be sent to me?
    jonty
    #489368
    only someone with Bosch tech access can get that. Dont know anyone on here with that
    jontymox
    I’ve done some further electrical tests, as advised by electrofix (Dave) and it does appear to be a board/relay fault.
    Will provide customer quote, and update.
    jonty
    #489370
    your tripping could be sparking relay contacts
    solder in a new relay and take it from there
    SWERV
    Do you have access to the BSH order management system? they do have wiring diagrams and test procedures for each model now.
    Merv
    #489372
    jontymox
    Thanks Merv,
    No access to the above BSH system.
    In fact, I think I’m losing my marbles 😮
    I decided to take another look at the fault/s and must confess that my test meter is faulty.
    I thought some of the earlier readings were odd, (Ohms resistance fine) but very low voltage to and from the board to the transformer.
    As Dave rightly stated, relays are either open or closed, leading me to recheck the above with an old analogue meter – which confirms 230 odd voltage to the transformer!
    So, back to the drawing board when I have time tomorrow…
    jonty
    #489373
    ok that means you problems are on the high voltage side
    fairly easy to diagnose that
    but does not answer tripping problem as high voltage side cant cause that
    SWERV
    Might be worth checking for a leaky high voltage capacitor.
    I can download the wiring diagram and send it to you if you send your email address.
    #489375
    jontymox
    Finally found the fault… severely burned magnetron antenna, although Ohms resistance tested fine at customers’ and at my workshop!
    I replaced the magnetron, and after a few seconds on a microwave setting serious arcing clear to see.
    Looking more closely with the magnetron removed shows arcing has burned a small hole through the cabinet casing.
    jonty
    #489376
    jontymox wrote:Finally found the fault… severely burned magnetron antenna, although Ohms resistance tested fine at customers’ and at my workshop!
    jonty
    you wont read any resistance reading as its just the antenna
    with the hole in the casing it will probably be beyond repair
    jontymox
    Agreed,
    Thanks to you, and Merv for your assistance.
    jonty
    #489378
    jontymox
    p.s I’m wondering what could cause such a drastic fault?
    #489379
    can be various things including dirty waveguide cover or comtamination on the aerial
    also customers dont seem to realise that its bad to turn microwaves on with nothing in it. those waves have to go somewhere so its more liklely to flash over
