bosch code
  • #71595
    dopper
    cant see this code in book, its a boch sis4140gb14 the spin and ens light flashing as well as the start it wont do anything
    anyone advise
    dop
    #381601
    Re: bosch code
    model number does not seem to be correct please check
    also what appliance is it washer / dishwasher ?
    check to see if any of the light flash a sequence
    ie 4 flashes stop then repeat
    dopper
    Re: bosch code
    sorry its wis24140gb14
    #381603
    dopper
    Re: bosch code
    and its a washer
    #381604
    Re: bosch code
    I have no idea what that error code represents but I can only suggest you check all the usual (motor,heater,base flood switch etc) to see if anything shows up?
    What have you checked so far anyway?
    #381605
    dopper
    Re: bosch code
    going to night to have a good look
    #381606
    nomadPaul
    Re: bosch code
    You will need the relevant spin speed led that’s flashing too.
    I.e if it’s the middle spin speed LED and the bottom 2 progress LED’s (spin and end ?) then that’ll be F:43 – motor fault .
    The combination of LED’s is important so if you post the correct one’s here , i’ll try and point you in the right direction.
    P.s If it is F:43 motor fault , you’ll need to also reset the machine via the test program after sorting the problem
    #381607
    dopper
    Re: bosch code
    cheers we couldnt get it out fixed in solid told them they would have to get it out!
