No i havent changed the control unit.But it was changed 4 months ago by a Bosch
approved agent due to recall.The cycle time for quick wash 35 comes up at 142 mins instead of 30 mins and the other cycles are wrong.The heat is working as i found yesterday on test.The reported fault to attend was soap dispenser failing to open.
Martin,are you saying corrupted rather than blown and therefore recoverable by recoding.I found the dispenser would open on a prerinse and as previously stated
machine does heat.Are there coding instructions available
Dispenser shouldn’t open in a pre-rinse, so perhaps the Control Unit was never configured from when the BSH contractors replaced it. I will dig out the coding instructions if you pm your direct email address. 😀
Can you remember how long the pre rinse cycle was? It should only be 15-19ish minutes. If it was between 29 and 42 minutes then the cycles are definitely out of synch.
