Bosch Combination/micro electic oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Combination/micro electic oven
  • #54444
    cornflakes
    Enr HBC 84K550B
    FD 8504
    client says oven is taking up to 25 to 30 mins to heat up to 200 degrees
    in convential setting,on air circulation a little longer. cooking period far to long on simple dishes.
    stripped down unit..suspected top or bottom elements had blown.
    both test out on megger test for continuity.
    voltage at BOTH top and bottom element teminals is 164volts when in circuit
    test out of circuit…244 volt (no load)
    I notice that the elements are wired in parralell..
    other wiring in harness appears ok..circuit wired direct from selector switch
    any one had this problem before. not knowing resistance of elements in the first place, its difficult to establish values. (i do suspect one of elements may have blown)
    clearly voltage drop is reason forlong heating up process, bearing in mind this is a very small oven chamber
    any help most welcome
    Graham
    #319635
    cornflakes
    Re: Bosch Combination/micro electic oven
    anyone got any ideas on this one
    #319636
    BobHope
    hi cornflakes,
    pm me an email address and i will send some info.
    Bob.
