Hi Folks
Went to this and custmer complaing still damp at end of cycle.
m/c is auto sense so wet n wrung out tea towel and tested with that – heat ok. Checked Cond unit was fairly blocked so cleaned all that out (best one to clean that i have come across so far) and tested again fault cured methinks.
But just before I left T/dry stopped – checked tea towel still damp – retried and cut out again – rewet and off heating again. So sensor picking up the difference although not enough to dry tea towel.
Could it be that the tea towel is not a big enough for the sensing to pick up acurately how dry it is and the m/c needs at least half a load in?
I cleaned the rim of drum where the sensor runs but no difference – did notice that the sensor appears not to be spring loaded altho it looks like it is making contact and running on the drum ok.
Have asked her to retry with a full load but if this fault persists is there other likly cause other than board?
Thanks folks – all comments appreciated as usual
Mick
