Bosch Condenser Dryer Model : WTL6106GB/05
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Condenser Dryer Model : WTL6106GB/05
  • #57503
    squadman
    Got one of these on the go at the moment the problem being that if you set the dryer on say Extra Dry the machine starts up and after a minute or two it switches itself onto Cuboard Dry the whole thing stopping with the Cuboard Dry light flashing ? Same on all the other programs except when you set it to Cuboard Dry where it works ok ?
    Anyone have any ideas as I cannot think what else to look at.
    #331348
    A1engineer
    Re: Bosch Condenser Dryer Model : WTL6106GB/05
    i think cuboard light flashing is a fault code meaning air circuit blocked (overheating), id check filters etc.
    not sure why i works on cuboard dry setting tho ❓
    #331349
    squadman
    Yes its a odd problem I will check the air flow as you suggest, thanks
    #331350
    squadman
    A1 you were correct ! blockage inside machine causing restricted air flow, removed and and cleaned out problem solved. thanks for your input 🙂
    #331351
    squadman
    #331352
    A1engineer
    no worries m8 glad to help.
