Bosch Condenser Dryer Small Belt Change
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Condenser Dryer Small Belt Change
  • #18090
    mjhservices
    Does anyone know how to change the small belt on a Bosch Condenser Dryer please.
    Regards to all
    Mark
    #177671
    gegsy
    Re: Bosch Condencer Dryer Small Belt Change
    Do you have a model number though please Mark?
    mjhservices
    gegsy wrote:Do you have a model number though please Mark?
    Yes its a Bosch WTL6304GB/02
    Regards Mark
    #177673
    gegsy
    Hi Mark
    I have never changed one to be honest. Have sent you email of exploded diagram. Hopefully Boro or BSH man may have more info.
    superfix
    Pretty easy job actually.
    Remove main belt, and front fan blade. At the rear end of the motor is a plastic handle that holds the motor in place. Remove the wires to motor then pull handle out.
    Hey presto the motor can then be removed, allowing the new belt to be fitted. Been awhile since I had to remove a motor so there may be a few extra steps involved, but it’s an easy job if memory serves. 😉
    #177675
    mjhservices
    boro wrote:Pretty easy job actually.
    Thanks for your reply although its not that easy.
    Regards Mark
    http://www.mjhservices.net
