Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch condenser dryer WTB84200/9
- This topic has 11 replies, 4 voices, and was last updated 1 year, 4 months ago by
HotDog.
November 27, 2024 at 6:19 pm #103097
HotDog
ParticipantSet dryer to dry program 221min start to dry then after approximately 5min it stops and the time jumps back to 221 open the door let the steam out then start again it’s flashing check filter but ok I have replaced front thermistor cleaned out pump area any advice welcome
November 27, 2024 at 10:02 pm #491787electrofix
Moderatorif you dont let the steam out what happens ?
can it be restarted then ?
November 27, 2024 at 10:23 pm #491788HotDog
ParticipantGood question I’m going of what the customer told me after doing all my checks I left it running till it did the fault I then opened the door obviously the steam came out then I started it again but she said it would just repeat the problem I run out of time and had to go
November 27, 2024 at 11:36 pm #491789electrofix
Moderatorwhen it fails does the display die and come back on ?
was thinking poss bad socket
November 28, 2024 at 5:55 am #491790Kentish
ParticipantIs the condenser clear?
sounds to me like it’s not.November 28, 2024 at 9:59 am #491791electrofix
ModeratorKentish wrote:Is the condenser clear?
sounds to me like it’s not.agree but assumed with the Bosch one it would be as itsw easy to clean, cant hurt to check
also possibility is blocked heater, have had a couple where the heater is blocked with a layer of lint at the bottom
November 30, 2024 at 6:57 pm #491792Hollytree_Technical
ParticipantHave you tried running a tap through the filter? I have found on some of these filters that they will look clean but the mesh will be full of micro dirt, if this is the case then the water will puddle on the filter instead of going straight through, usually rubbing the filter between your fingers while putting the water through will be enough to clean them.
Jem
December 3, 2024 at 6:18 pm #491793HotDog
ParticipantThanks for your help the water had formed a puddle under the filter the machine was slopping forward so I assumed that’s why there was a pool the filter did look ok but you could be onto something there I will be going back Friday to check element as suggested and filter
December 6, 2024 at 9:41 pm #491794HotDog
ParticipantNo luck with this checked every thing clean condenser checked heater when it goes into fault it’s check filter if you press start button it won’t continue unless you open door and let the steam out it does this a couple of times then it goes ok and completes the program very strange doesn’t make sense tempting to change element
December 6, 2024 at 9:46 pm #491795electrofix
Moderatorfilter in the door have you held it up to the light and checked it
get a lot of them block over time and need washing
December 6, 2024 at 9:54 pm #491796electrofix
Moderatorok have a careful look at the element. look for elements that are distored or closer together. what i am looking for a poss hot spots
if all looks ok you can get the NTC on its own which will be used to sense fliter. there is also one at the fron which maybe involved
December 9, 2024 at 5:48 pm #491797HotDog
ParticipantOk thanks Dave I will give that a go and get the ntc I did hold filter to the light on Friday when I went back but it was ok I also had a new condenser which I had acquired and left it for the customer to try but it made no difference
