Bosch Condenser Dryer WTE84103/GB
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Condenser Dryer WTE84103/GB
  • #57714
    Kielykid64
    I was called to service this Dryer as it It was just giving 2 beeps and Nothing else, Checked the water chamber on underneath the conderser pump cleared out the fluff. cleaned the probe in front at the lint filter and the sensor at the element had a coating of lint . I didn’t remove the motor side of the cabinate , did I miss something ? There are no burn marks, the element is metering OK. I was compeatly beaten on this one !
    Had to walk away,
    Thanks ,
    Maurice
    #332064
    don
    Re: Bosch Condenser Dryer WTE84103/GB
    Hi Maurice
    If you are trade then why not apply for trade access there is so much more info to be had.
    Don
    #332065
    nomadPaul
    If it just beeps twice on trying to start , but doesn’t actually start , then it could well be the door lock faulty , not seeing the door in the closed position.
    #332066
    wizard
    I had one of these doing exactly this just last week. I came to the same conclusion as nomadpaul, so checked the door lock and connections to pcb. No faults found but when it was all back together it ran perfectly. Put it down to a poor connection on the pcb. It’d be worth giving all the connectors a wiggle. Wizard
    #332067
    Kielykid64
    Thanks Guys, I will keep it in mind for the next One !
    Maurice .
    #332068
    octumnal
    how is the interlock replaced on this,cant see any screws?
    #332069
    octumnal wrote:how is the interlock replaced on this,cant see any screws?
    Slide ‘n click fitting. 😉
