BOSCH condenser T/D — WTL 6106GB/07
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH condenser T/D — WTL 6106GB/07
  • #20403
    brett1611
    Hi – customer complaint is NOT HEATING FOR VERY LONG. I found condenser was FULL of debris. Cleaned it and normally expecting it to work but it didn’t. It works ok until it changes direction then whatever setting it’s on it just goes to the END light , turns in other direction and then thats it !!!!!!!!!! ???? ANY IDEAS
    #186968
    Re: BOSCH condenser T/D — WTL 6106GB/07
    I wonder if the water tank fills with water during use? I suspect not and that the pump hose to the water tank is blocked with that same debris? 😉
    Behind the condenser matrix that whole area will be flooded and gunged up too! Take the hose off at its joiner halfway up the back panel, clean the nozzle into the tank and then blow through the pipe into the pump chamber to be sure its clear! 😉
    A flush out with a bit of clean water wouldn’t be a bad idea too! 🙂
