Bosch condenser T/Dryer
  • #54119
    PGS
    ENR. WTE84103GB/05. Hi I have been to above appliance which is leaking at the bottom L/H side after 5 mins use, pump is running and filling water chamber. Any ideas and is there any mods. Cheers Paul.
    #318500
    Jazzmeister
    Re: Bosch condenser T/Dryer
    dismantle and check cover under drum lh side as u look at it …may be blocked with lint from the condenser!
    Jazz
    #318501
    S1MON
    Also has condensor not sealing correctly causing it to leak
