Hi. Girlfriends tumble dryer filter clean light coming on after a couple of minutes causing the machine to stop. Found that the condenser was blocked-up which I cleaned out. Wetted a towel and runged it out and put in the machine. Started off and ran for 30 secs then the machine`s display went dead never to return again! So now it is totally dead/snuffed it. The fuse is fine power to suppressor, wires the go directly to pcboard, yes that`s a £242 pcb. Do you think what I`m thinking abnd it is the pcb that is nuked? Am I missing anything? There was no bang. I took the pcb off the fascia panel and had a look but can see nothing wrong with it visually. Any ideas please?
