Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Condensing Dryer : WTE86304GB/05 Steams Up
- This topic has 14 replies, 6 voices, and was last updated 12 years, 2 months ago by
neilsukwg.
January 24, 2014 at 3:25 pm #79190
neilsukwg
ParticipantFD 8707 200179
This machine leaves the clothes hot, wet and steaming, with water covering the condenser plates..
I have thoroughly cleaned pump, pump trough and associated pipework, the pump seems in good condition and I can hear it running during the programme.
Not seen many of these, what could i be missing?..
January 24, 2014 at 3:32 pm #408332nomadPaul
ParticipantRe: Bosch Condensing Dryer : WTE86304GB/05 Steams Up
Presuming the condenser is not blocked , you might need to look at the small fan blade on the FRONT of the motor. This fan blows cold flowing air over the condenser . These can block up with fluff thus making them much less efficient.
January 24, 2014 at 3:37 pm #408333Martin
Does the water container fill up? Try removing the container then pouring a glass of water into the back of the empty cavity (that should drain into the pump chamber area) then refit the water container and switch on. Within 10 seconds turn off the machine and that water should have pumped back into the container.
January 24, 2014 at 3:40 pm #408334Andy jones
Certainly sounds like some sort of blockage
January 24, 2014 at 3:56 pm #408335neilsukwg
The water drawer does fill to some extent, but the cust reports that after 15 to 20 mins the machine cuts out, presumably overheating,
when i tested it after a good cleaning out it was still running after 20 mins but opening the door resulted in clouds of steam billowing out,
Think i will try it with the pump pipe laying on the floor to see if it clears any better, and will check the front fan,
why are awkward jobs always miles from base? ๐
January 24, 2014 at 3:58 pm #408336Andy jones
I know I’m stating the obvious but is the condenser definitely clean
January 24, 2014 at 4:19 pm #408337neilsukwg
First thing i checked, yep, daylight in all directions, clean as a whistle!
January 27, 2014 at 8:46 pm #408338jason1970
definitely check the cooling fan!
January 29, 2014 at 6:55 pm #408339neilsukwg
Back today, made cooling fan spotless, checked again for pump operation, customer rang, its still the same?
January 29, 2014 at 7:52 pm #408340Martin
Opening the door to clouds of steam surely indicates an airflow blockage of some kind to the condenser. And the water container to only partially fill in spite of no blockage from the pump to the container again indicates a blockage in the condenser area. Fluff, animal hairs or the scented t/dryer sheets the usual reason.
I realise you’ve covered all of the above but that, I believe, is the only possible explanation for the fault. ๐
February 6, 2014 at 5:12 pm #408341neilsukwg
Andy jones ยป Fri Jan 24, 2014 3:58 pm
Some improvement the dryer now managing small loads after a thorough hosing out of the condenser, but still fails on large towel loads,
customer reports machine stops completely, no display for about 10 minutes, full of steam etc
February 6, 2014 at 5:19 pm #408342Martin
The base area under and behind the condenser matrix is spotlessly clean is it?
October 10, 2017 at 9:43 am #408343codlets
Old thread I know but do you remember if you got to the bottom of this one Neil ? Thanks, Leon
October 16, 2017 at 9:27 am #408344neilsukwg
No it got the better of me I asked customer to try somebody else..
October 16, 2017 at 6:36 pm #408345codlets
Fair enough, I am about to give up on this one too !
