Bosch condensor dryer
  • #23465
    A1TEC
    Had a quick look at this today,machine flashing on the iron dry light and buzzer sounding.Model WTL 6307 GB.
    Any pointers and is this a fault code?
    Thanks in advance
    John.
    #198216
    nationalhomecare
    Re: Bosch condensor dryer
    The fault described is because NTC R2 is out of range or at fault, this is the one located on the heater box at the back.
    Its resistance should be 25k ohm at 25’c
    Check that its not all covered in crap too as thats quite common.
    And the condensor at the front also gets blocked up with fluff and causes them to throw up some funny faults.
    BSH Part number for the said NTC is 163297
    Hope this helps! 😉
    #198217
    A1TEC
    Thanks for that,will give it a try. 😀
