Hi just wondered if anyone can help with this tumble dryer will not respond to the start button start light just flashes and a beep i thought door switch but when you close the door you can hear the relay on the board click so not so sure now is there a test sequence on these machines any help would be good thanks Larry.
Try starting it with the door open….
Do you get exactly the same response as if starting it with the door closed ? If yes , then it’s likely to be the door lock or failing that , the board
