Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Bosch Condensor Tumble Dryer Not stopping when container full
- This topic has 31 replies, 2 voices, and was last updated 5 years, 1 month ago by
Watson306.
March 17, 2021 at 11:01 pm #475099
Moderatoris the pump ok
cant remember if we checked
March 18, 2021 at 10:26 am #475100Watson306
Participantelectrofix wrote:is the pump ok
Thanks so much for your help so far.
I’m not sure if we have – I think you thought it might be gummed up?
But I can’t really see anything – I could take a pic if it’s useful (but I’m assuming it would be obvious)?
If not what do I need to check on the pump Dave?March 18, 2021 at 10:50 am #475101electrofix
Moderatorsee if the pump revolves when you turn it and check the impellor, use a multi meter to see if the coil is ok
March 18, 2021 at 12:32 pm #475102Watson306
Participantelectrofix wrote:see if the pump revolves when you turn it and check the impellor, use a multi meter to see if the coil is ok
The pump revolves.
The impellor appears OK.
I get a resistance reading with the multi meter across the field, but what would you set it to and what should it read?
March 18, 2021 at 1:47 pm #475103electrofix
Moderatorwell unless your getting millions of ohms then it must be ok, we are sort of cluching at straws now
well not got a lot more i can think of you can check pump wires continuity. after that look at the board and see what controls it
March 18, 2021 at 3:27 pm #475104Watson306
Participantelectrofix wrote:well unless your getting millions of ohms then it must be ok, we are sort of cluching at straws now
Is there a way I can check those prongs?
Or is it looking like the control panel?
Could I run the dryer with the pump removed briefly and see if it works?March 18, 2021 at 8:06 pm #475105electrofix
ModeratorWatson306 wrote:
I
yes as long as the wires cant touch anything that will damage them or cause a shortDave
March 19, 2021 at 3:08 pm #475106Watson306
So I turned it on with the pump assembly removed and the pump turned.
March 19, 2021 at 3:14 pm #475107electrofix
Moderatorwell that means it can pump water. does the draw get full
if no suspect blockage between pump and draw
dave
March 19, 2021 at 7:04 pm #475108Watson306
ParticipantApparently the drawer gets full and then overloads onto the floor.
March 19, 2021 at 7:39 pm #475109electrofix
Moderatorwell since it will not fill up each load there are 2 answers
1 empty it more often
2 change the system so it pumps the water down a drain instead of into the drawDave
March 19, 2021 at 8:01 pm #475110Watson306
Participantelectrofix wrote:well since it will not fill up each load there are 2 answers
Thanks Dave.
Do you not know what the issue could be?
Or does, it sound like a control panel issue?March 19, 2021 at 8:07 pm #475111electrofix
Moderatorthink we have exhausted all the things apart from the panel and cant see that being cheap
March 19, 2021 at 8:25 pm #475112Watson306
Participantelectrofix wrote:think we have exhausted all the things apart from the panel and cant see that being cheap
Is there a way I can test the prongs?
March 19, 2021 at 8:32 pm #475113electrofix
Moderatoras long as they are clean and you get continuity from the prongs back to the board then all it can be is the board. the board measures the level of the container and if its not registering then can see it easily being the board
