Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Bosch Condensor Tumble Dryer Not stopping when container full
- This topic has 31 replies, 2 voices, and was last updated 5 years, 1 month ago by
Watson306.
February 12, 2021 at 10:59 am #99123
Watson306
ParticipantHi Guys,
A family member of mine has a Bosch Condenser Tumble Dryer and the the tank fills but doesnt stop when its full.
I’m guessing its some kind of sensor but I havent had a look for them yet, and was wondering if anyone has had experience of this?Thanks in Advance.
February 12, 2021 at 1:31 pm #475085electrofix
Moderatorwhats the full Enr number ?
February 12, 2021 at 3:53 pm #475086Watson306
Participantelectrofix wrote:whats the full Enr number ?
Apologies I have since found out that it is a Siemens and not a Bosch.
My mistake as I could have sworn it was a Bosch, but the number is WT46E381GBFebruary 12, 2021 at 9:43 pm #475087electrofix
Moderatorto be honest they are the same dryer anyway so no real problems
yours is the older one with the float on the pump
its mounted left hand side rear at the bottom. you have to remove left side to access which is a bit tricky as front control panel has to come off to get all the screws
you will find its gummed up and needs cleaning
item 512 on diagram
https://www.siemens-home.bsh-group.c…glebox=tb0512/Dave
February 12, 2021 at 11:35 pm #475088Watson306
Participantelectrofix wrote:to be honest they are the same dryer anyway so no real problems
item 512 on diagram
Thanks Dave.
Doesn’t sound too bad to be honest.
Will it just need cleaning?
Is there any situation where it will need replacing?
February 13, 2021 at 12:29 am #475089electrofix
Moderatortheres always an exception but its unlikely, the float is probably just stuck down with goo and soggy lint
March 16, 2021 at 11:11 am #475090Watson306
Participantelectrofix wrote:theres always an exception but its unlikely, the float is probably just stuck down with goo and soggy lint
Hi Dave,
Apologies for the late reply.
I’ve only just got it in front of me.
I’ve attached a pic (which I can’t actually seem to upload) – could you point me in the right direction as to where I can find this part in your pic? And some guidance how to access it if it’s not too much trouble?Thanks in advance.
March 16, 2021 at 11:13 am #475091Watson306
ParticipantHere we go :
March 16, 2021 at 4:21 pm #475092Watson306
ParticipantWatson306 wrote:Here we go :
For some reason that didn’t work – try this:
March 16, 2021 at 5:24 pm #475093Watson306
ParticipantI actually think the pump you were talking about Dave is accessible from the back of the machine.
I’ve found a little cover and then what appears to be a pump module behind it.
I’ll take another pic shortly.
But I’ve had a brief look and it looks relatively clean in all honesty, but I might not be looking in the right place for the lint.
But I’ll post a pic up.March 16, 2021 at 5:31 pm #475094Watson306
ParticipantMarch 16, 2021 at 11:03 pm #475095electrofix
Moderatorthe 2 pink wires connect to 2 the water level sensor
dave
March 16, 2021 at 11:16 pm #475096Watson306
Participantelectrofix wrote:the 2 pink wires connect to 2 the water level sensor
dave
There’s two probes into the tank below from those.
I can’t really see any lint or dirt tho.March 16, 2021 at 11:27 pm #475097electrofix
Moderatorok check the wires back to the timer
March 17, 2021 at 4:05 pm #475098Watson306
Participantelectrofix wrote:ok check the wires back to the timer
I’ve checked the pink wires back to the control panel and there is resistance on both wires.
