bosch cooker hood dke645dgb
Home Forums Public Support Forums Help And Support Cooker And Oven Forum bosch cooker hood dke645dgb
  • #25597
    henryV
    Hello
    i have a bosch cooker hood dke645dgb
    it has 9″ x 10″ x1″ black filter (charcoal?)
    1. how often should this filter be replaced?
    2. is it necessary to get a genuine bosch filter or are there cheaper alternatives available?
    3. where is the best and most competitive place tobtain a replacement?
    many thanks
    HenryV
    #206555
    gegsy
    Re: bosch cooker hood dke645dgb
    Which one please DKE645dgb /01 /05 /06 ?
    henryV
    gegsy wrote:Hi
    thanks for your reply
    i confirm it is an 05
    HenryV
    #206557
    gegsy
    You can go to most electrical/hardware stores and buy a universal pack.
    Basically you use the old filters as templates and cut to size.
    As for changing, how long is a piecs of string 😕
    Rule of thumb would be 6- 12 months depending on use. Tell tale signs are visual (greased up) and odour (increase of smell in room from cooking) and poor extraction (which s the same if the metal grease filters are clogged also)
    Thats the charcoal filters acknowledged, the metal grease filters usually can be dishwashed (check first)
    HTH
