Bosch Cooker Hood Lights not working and fan limited
Home Forums Public Support Forums Help And Support Other Appliances Bosch Cooker Hood Lights not working and fan limited
  • #87553
    bobbyollox
    Bosch cooker hood has stopped working. Bulbs wont come on even though they tested ok with a multimeter. The fan up and fan down buttons dont do anything, but the fan max button takes it to fan level 1. IT all used to work fine a little while ago.
    I guess it is the switch and control board behind the buttons which is knackered – I found a genuine replacement part for £197 !!!
    a) before I fork out £200, is this the likely solution – any views ?
    b) from experience, is this this good money after bad – I guess it is about 10 years old – are other bits going to start breaking, or is this a common enough fault that isnt an indication its on its last legs. ?
    Many thanks in advance.
    #435241
    melec
    Re: Bosch Cooker Hood Lights not working and fan limited
    I just got my backside severely slapped with one of these !
    Assuming yours is controlled by a module which is likely then
    I would not recommend buying the part / module yourself in case motor has caused the fault initially and zaps new module ( speaking from experience here !!)
    Get BSH to do it or better replace whole Extractor is my shout
