Bosch cooker tripping electrics
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch cooker tripping electrics
  • #38774
    dna
    B1861N2GB/05
    Hi have this bosch cooker that trips the electrics when th ecustomer turns off the appliance. didn’t happen when i was there. Any ideas. ASAP
    Thank you
    #259951
    Re: Bosch cooker tripping electrics
    dna wrote:when the customer turns off the appliance.
    That’s an odd one for sure? RCD, earth bonding type problem maybe? 😕
    Means you’re gonna need to get your Loop Tester out on this one, or megger everything in there at least?
    #259952
    dna
    YEah it is wierd don’t know what could cause it to do this apart from the switch itself.
    #259953
    gegsy
    Dansta had a same fault with an Electrolux oven.
    Turned out to be circotherm element 😀
    nomadPaul
    I can’t rememebr exactly which model but i have had problems with the switch selector on these ovens ‘sparking’ when switched on or off. It may be worth checking the selctor switch for any signs of scorching or burning…especially on the underneath.
    i think the spark/contact break is enough to upset a sensitive 30Ma RCD
    #259955
    hilly
    i had this fault on a bosch it turned out to be the fan element, it tested ok on meter, so i replaced switch n then the stat with no joy, so i replaced elememt with success
    paul
