Bosch countdown…
Viewing 15 posts - 1 through 15 (of 15 total)
  • #60354
    cooky
    Hi,we got a couple of bosch washers enr.WFO2465GB/01.these have the small digital countdown window.These machines both countdown from 6 mins straight down to 1 minute and so do not do a final spin.They wash heat up and empty no probs.Any help greatly received..
    thanks..
    cooky….
    #341889
    Re: Bosch countdown…
    You must remember that the SPIN ONLY cycle is there for HAND WASHED items only therefore it only spins at 800rpm for a minute or so then goes to zero. It will not do a long fast spin on that setting.
    However, on a main ‘cottons’ wash it should do a full spin, if not then there’s an issue with the motor…..HTH?
    #341890
    nelson
    Have a look at this….
    http://ukwhitegoods.co.uk/modules.php?n … 84ecadc2ea
    #341891
    nelson wrote:Have a look at this….
    What?
    #341892
    nelson
    This link….
    ๐Ÿ™‚
    #341893
    Just takes me into the UKW sign-on page for some reason….?
    Could you double check that link for me as it ain’t happening here matey? ๐Ÿ˜•
    #341894
    nelson
    Sorry if that link isn’t working for you, it does fo me :con: anyway I’ve just copied and pasted it here:
    Bosch Exxcel wfo285sgb/01 skips spin
    UK Whitegoods Forum Index ยป Trade Technical Enquiries
    Author Message
    nelson
    UKW Top Poster
    Posted: Thu Feb 07, 2008 8:44 pm
    Hello, can anyone help with this one, the machine runs through the whole wash. The wash time indicator counts down to 7mins remaining then skips to 1 min remaining without picking up into high speed spin.
    I was originally called out because the machine did not spin and still had water in the drum when I tried to drain the machine the pump was not working, so replaced the pump.
    However the next wash the machine again did not spin but this time it had drained completely but did as above.
    I assumed the module may be faulty so sent it to QER to test but they say no fault found (that said when I spoke to them before hand they had not tested/repaired this particular module before). So I am still not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure if the board is faulty or not and a new one from Bosch is 106 quid (a bit of an expensive guess!!)
    Please help.
    New to UK Whitegoods? Click here to get a starter pack, all the stuff you need!
    gegsy
    UKW Moderator
    Posted: Thu Feb 07, 2008 10:31 pm
    May be carbon track over on motor and/or low brushes; worth a try first
    Have had two in the past, one was module, other was motor
    Micky 32
    UKW Top Poster
    Posted: Fri Feb 08, 2008 9:56 am
    I remember a similiar fault on it’s Siemens sister washing machine. The motor was faulty even though it washed ok etc. If the brushes are ok it’s the motor.
    nelson
    UKW Top Poster
    Posted: Sun Feb 10, 2008 7:51 pm
    Thanks Gegsy & Micky,
    I checked the brushes the first time I called out and they were ok. I think I’ll see if I have a motor in the work shop that I can plug in and try before I order a new module.
    Thanks again.
    UKW Super Poster
    Posted: Sun Feb 10, 2008 7:57 pm
    Another thing you could try Nelson is to strip the motor, give the whole unit a darn good flush out with WD40 to clear away all the carbon dust (as Greg mentioned ). Clean up the commutator with a bedding stick and try it again? If that fails and you reckon the Module checks out OK? Then the motor is a duff’un
    HTH?
    nelson
    UKW Top Poster
    Posted: Tue Feb 12, 2008 12:42 pm
    Cheers martin, I’ll give it a try.
    nelson
    UKW Top Poster
    Posted: Fri Feb 15, 2008 8:21 pm
    Thanks again Martin, Stripped the motor down, dowsed it in WD40 gave my comm stick a bit of welly and hey presto motor back from the dead. Very happy customer
    #341895
    The one above takes me to a login page as well. ๐Ÿ˜•
    Weird that, can anyone view that thread from THIS link?
    I copied the hyperlink from the address bar at the top of the screen BTW.
    rolf
    That one works ok
    #341897
    washermanuk
    sorry takes me to log in page? ๐Ÿ˜ฅ
    #341898
    That is weird. Iadom’s link works for me but not Nelson’s. I tried several things. I copied and pasted the link into a new tab and shortened it to the home page address and it still treated me as if I was logged out. ๐Ÿ˜•
    UKWG addict? Who, me?
    Mike.
    #341899
    nelson
    Your link works for me Jim, but then so does mine ๐Ÿ˜†
    #341900
    nelson wrote:Your link works for me Jim, but then so does mine ๐Ÿ˜†
    Your link though Nelson should stop before the words BOSCH&SID, so god only knows what all those letters and numbers are that are stuck on the end?
    You’ll have to tell us how you got that ‘link’ up in the first place, suspect you must be doing something wrong? Who’s SID anyway? ๐Ÿ˜›
    #341901
    nelson
    Wasn’t Sid the guy that everyone had to tell about British Gas ๐Ÿ˜€
    As far as my link I just copied and pasted the contents of the address bar, right or wrong I am not sure, but it is the way I have always done it, but I stand to be corrected as I am no puta expert :con:
    #341902
    Martin wrote: so god only knows what all those letters and numbers are that are stuck on the end?
    Hope it’s not a nasty virus 8O.
    Mike.
