Re: Bosch D/W
robbra wrote:it sometimes stops with 17 mins remaining…she always uses economy but has been trying quick wash and it is ok.
Turbidity sensor problem then most likely? Does it heat up OK I wonder?
robbra wrote:to cancel a programme hold the two buttons in but to change it the m/c must be switched off.
Now this is a bit more scary? Are you saying that using the correct 2 button procedure to ‘reset’ the machine, it won’t?
Because if so, the Module is up the swanney! 😕
