SGS43A18GB27 Dishwasher.
my engineer replaced a blown pcb 489607 recently, had a diagram in the box about changing the plugs Sicasyn for G and H controls, cutting links etc, (this is off the instruction sheet with the pcb)
“In case of an equivalent control the wire at the module (terminal clamp 5) of the appliance up to KI12 must be cut through and be fitted to the enclosed double -terminal at the wire (terminal clamp 7)
What is KI12?
It was an equivilant style and connections in the same postions but there are no numbers on the pcb or blocks.
But translating this i think means cut the wire that goes to no 5 and join it to 7?
So fitted it and followed as best as possible the instructions.
It works the same if you do or dont cut the link.
It will not select the main 65 degree wash only without pressing the next button at the same time.
Any suggestions please.
Steven
