Bosch d/w keeps filling all day
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch d/w keeps filling all day
  • #55181
    a1al
    hi guys
    This is a bosch SGV53E03GB / 74 Dishwasher
    The problem is it keeps filling up and then the anti flood switch brings on the pump and empties out some water then it brings more water in and this will go on all day, can’t blame the water level switch as i can’t find one anyone any ideas????
    please!!!!!!
    #322210
    nomadPaul
    Common problem and loads of posts on it. Faulty flow sensor ( impellor jug ) Part no 424099. Its fitted at the rear left and is a white cyclindrical object inline with the inlet hose just before it enters the water matrix.
    #322211
    a1al
    Re: Bosch d/w keeps filling all day
    Hi Paul
    Thank you very much for your reply
    Is this part like a small turbine,
    Dont take this the wrong way
    but how sure are you this will fix it, because I was just advised a couple of weeks ago to change the programmer which I did and that seemed to fix it at the time, but same problem back again.
    Again many thanks for taking the tine to reply
    Al
    #322212
    He does them all day, everyday……
    a1al
    Many Thanks for that Paul
    Hi Chris do you know if ukwhitegoods shop keep this part in stock
    Al
    #322214
    a1al
    Another result for ukwhitegoods
    Just to let everyone know that replacing the water flow sensor/meter/jug done the trick.
    Again many thanks nomadPaul
    a1al
