Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch d/w SGI43E02GB/08
- This topic has 14 replies, 5 voices, and was last updated 18 years, 7 months ago by
senseib.
September 4, 2007 at 11:05 am #30272
senseib
ParticipantHi guys, just got this m/c in – will only fill & empty nothing else!
Fills for 30 sec then empties, fills – empties continously on all prog’s.anyone had this before on these?
Brian.
September 4, 2007 at 3:07 pm #226597nomadPaul
ParticipantRe: Bosch d/w SGI43E02GB/08
The few times that i’ve had this fault , it has been caused by a faulty water inlet flow meter – Does it have the flow meter fitted ?
September 4, 2007 at 4:28 pm #226598senseib
No I dont think so! Dont know what controls the inlet (module perhaps!) – but it does have an aquastop attached and a safety float inside.
September 4, 2007 at 5:46 pm #226599gegsy
This model does have a flow meter/impellor jug fitted.
If required p/no 424099.
I would also look at the transfer ribbed hose (the usual suspect) aswellGreg
September 4, 2007 at 8:37 pm #226600senseib
Hi Gegsy, Thanks for your reply. Where on the machine is the ribbed hose & which is the best way to get to it? Is it that the hose gets blocked that causes the problem?
Brian.
September 4, 2007 at 8:44 pm #226601gegsy
Hi senseib
You must the only person not familiar with THAT hose 😀
Its situated behind lower front plinth and runs from the metering unit to the sump. It is ‘O’ringed on both ends so will pull off 😯
Make sure you completely empty sump water before removing the hose (gets a wee wet if ya don’t 😉 )Greg
September 4, 2007 at 9:01 pm #226602senseib
YEP! Know the hose in question now – gets silted up then slows flow into machine. Bit of a brain seizure there – ok now.
I think my signature is very accurate at times 😆
Thanks again Gegsy :rolls:
September 4, 2007 at 9:21 pm #226603superfix
I would agree wiyh Paul on this one.
More than likely the flow meter goosed.
September 4, 2007 at 9:23 pm #226604gegsy
Yup, terrible reliablility.
What I would say is when you replace the impeller jug, make sure you make a note of the orientation of the old one, its imperative 😉Greg
September 4, 2007 at 9:31 pm #226605senseib
Never changed one of these before – tips on accessibility & best way to fit new part would be appreciated!
September 4, 2007 at 9:34 pm #226606gegsy
You have mail, section 4.4 😉
September 4, 2007 at 9:48 pm #226607senseib
Thanks Greg, your a star 😉
Brian.
September 7, 2007 at 10:32 pm #226608BSH-MAN
gegsy wrote:Yup, terrible reliablility.
And the angle 😉
September 7, 2007 at 10:41 pm #226609gegsy
Oh yea and the angle :study: 😀
September 7, 2007 at 11:51 pm #226610senseib
No more than 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} – 4.4 see i did read the bumf!
You were absolutely right it was the flow meter guys – big PAT on the back to all those who got it right 8)
Brian.
