It fills and pumps out then fills – heats & pumps out – but will not fill on rinse. The circulating motor just runs and runs without water. Not sure what regulates the water intake on this machine, cant see any p/stat or float switch 😕
senseib wrote:cant see any p/stat or float switch 😕
The water level is timed by the module, the float switch in the centre of the tub is the anti-flood control. Check also that the aquastop air tube is clear? 😉
At the risk of appearing dumb! where is the aqua stop air tube located on the machine? It only has a standard inlet hose, not one of those with the valve fitted at the tap end.
Brian.
