Bosch (D/W) SGS43T22GB/01
  • #52153
    rocker
    This a currys sold dishwasher, the Enr is not reconised by bsh..its the type with the mushroom plunger….the machine fills with water runs for a very short time then aborts, water pumps then keep pumping..I have taken the cover off base, and found a small card that slots into bottom of tub with a 2 wired plug conected, I have metered this unit, reading open circuit, (is this correct) also the part number please. John.
    #310762
    nomadPaul
    tbh John , it sounds like its leaking into the base and operating the flood protection system .
    Wasv there any traces of water once you took the metal baseplate off ? First thing i’d check is the securing nut on the salt pot where it meets the tub. Take off the salt pot lid and see if the securing nut is loose . I have had a couple where this is loose and water is leaking into the base by the salt pot lid.
    #310763
    clivejameson
    Re: Bosch (D/W) SGS43122GB/01
    Is this one with an inline water meter (jug impellor)…i seem to recall having one where this went O/C and the machine aborted and ran the drain pump early on presumably because the pcb didn’t receive any impulses from it?
    #310764
    rocker
    Hi Gents, no sign of water in base…. No sign of impellor jug !!!
    #310765
    Washman
    Check that model number there should be a letter between the 43 and 22
    Mike
    #310766
    rocker
    washman, you are correct the Enr SGS43T22GB/01 thanks John.
    still need help to dianose fault….please
    #310767
    clivejameson
    Ahhh this is the one with the little float magnet at about the 6 o’clock position of the sump moulding.
    Locate it, pop off its cover, remove and clean it, check for condensation in the clear half of the float (indicates it’s leaking)
    Note which way up the float fits when taking it out…IIRC the clear half is uppermost but it’s been a while since i’ve done one 😉
    HTH?
    #310768
    rocker
    Cheers Clive, have removed and cleaned the magnet, but beleive there was condensation so I will change this part, and retry. thanks John.
    PS. you dont know the part Number by any chance!!
    #310769
    rocker
    Re: Bosch (D/W) Enr SGS43T22GB/01
    Can anyone please tell me the part number of this sliding magnet, I have rang bsh, there dont know the part I mean, also I cant see it on there drawing!!
    #310770
    Washman
    Re: Bosch (D/W) SGS43T22GB/01
    Part #188106 float .
    Hope that helps, it is on the drawing on Bosch Eshop page 5 for that model
    Mike
    #310771
    rocker
    Mike. many thanks John.
    #310772
    adv
    if float fauty or gunged up machine usualy over fills an floods kitchen. 😆
