hi
customer says it fills but the check water light is on?
is this a flow meter prob/pressure switch?
i dont think there is the usual pressure chamber on this model.
thanks
Most likely needs a new flow meter (impellor jug) pt no. 424099 although very occasionally i’ve had poor connections to it (squeeze the connector block to gain tension on the contacts)
it was indeed the flowmeter.but i just replaced the micro reed switch on it .only about 2euro instead of having to buy new flow meter at about 30 euro.
Thanks 😀
Galway wrote:it was indeed the flowmeter.but i just replaced the micro reed switch on it .only about 2euro instead of having to buy new flow meter at about 30 euro.
Thanks 😀
Next time call me, ill do you complete flowmeter for 29 euro’s 😉
