bosch d/w sgs45e6gb/64 pump acess
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch d/w sgs45e6gb/64 pump acess
  • #68810
    JENKS
    can anyone tell me the easiest way to access the circulation pump on above machine.fault i have is top spray arm u/s,i think foriegn body in pump dropping pressure
    #372828
    Re: bosch d/w sgs45e6gb/64 pump acess
    JENKS wrote:can anyone tell me the easiest way to access the circulation pump on above machine.
    Yes just read THIS THREAD
    JENKS wrote:fault i have is top spray arm u/s,i think foriegn body in pump dropping pressure
    The fault is more likely to be a faulty water point diverter inside the heater box (Pt No 483058) than anything blocking the circulation pump. 😉
    #372829
    JENKS
    would a faulty water point diverter still allow the bottom spray arm to turn
    #372830
    Criscold
    Yes it would, If nothing is blocking the inlet to the circ pump then I would go with the heater box as Martin says and I have done a few because of this fault. is the machine getting enough water ?
    #372831
    JENKS
    yes machine is filling as normal,lower spray arm turns but upper does not even tho it does have water coming through it but i presume pressure is not enough to turn it.
