this d/w is sticking on rinse and just continually washing upon inspection of the d/w found that it is heating during the rinse i asume that it is the pcb at fault or could it be someting else?
It will heat during the final rinse/drying cycle 🙂
As a guide, water should be half way up lower spray arm spigot.
IMHO I reckon the heat could be transient heat from the recirc pump being on too long or our usual suspect the depleted solder pad on the heater relay pin.It may just making slight contact to heat water but not enough to bring it to temp to continue 😀
Check that PCB would be my first point of call 😉
customer rang since i poked around in the machine the other day its been ok, went back today and resoldered the relay just incase so fingers crossed!!!!
