Bosch d/w SGS5318GB/12
  • #29299
    senseib
    Even when I reset the control module the circulating motor is running all the time on this machine & it wont drain unless i actuate the overfill switch.
    Can anyone advise?
    Brian.
    #222661
    Redflame
    Re: Bosch d/w SGS5318GB/12
    Sounds to me like you have a live feed to the motor – Could be module fault or could be element down causing neutral fault. Anyone else ? Martin ?
    #222662
    senseib
    Thanks for your prompt reply Redflame. I tested both the heater element & the motor for earthing faults both ok.
    I suspect that it’s the control module, but always reassuring when others point the finger in the same direction.
    Does anyone know differently though?
    Brian.
    #222663
    gegsy
    Have sent some info that may help you.
