Bosch D/W SGS53C12/21 Overfilling?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch D/W SGS53C12/21 Overfilling?
  • #50728
    laurenceuk
    Not worked on a Bosch with a flow meter before.
    Detached the meter and cleaned the glass phial and made sure contacts are good.
    Checked module for physical damage and contacts.
    But still the `check water` light illuminates and then continues to fill for a
    short while longer until it begins to empty and fill alternatively – for ever… probably.
    Should I suspect a faulty flow meter (Connect description = Impeller Jug 5045171450938).
    Laurence
    #305758
    Re: Bosch D/W SGS53C12/21 Overfilling?
    laurenceuk wrote:Should I suspect a faulty flow meter (Connect description = Impeller Jug 5045171450938).
    A faulty Impellor Jug (BSH Part no. 424099 @ £9.10) is the likely problem yes. Dunno about the Connect part number though as I always buy direct from BSH. I wouldn’t mind betting Connect don’t sell them to you for £9.10 though? 😉
    #305759
    laurenceuk
    Thanks Martin,
    I will give it a go.
    Laurence
