Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch D/W SGV53E03GB/74 “Staining”
- This topic has 8 replies, 6 voices, and was last updated 17 years, 3 months ago by
a1al.
January 2, 2009 at 6:41 pm #42223
a1al
ParticipantHi everyone
Been out to this one today, customer says it is leaving white grity stains on the dishes most visible on the glasses but you con feel it on everything else aswell
any ideas??
Thanks al
January 3, 2009 at 12:10 am #272785eastlmark
ModeratorRe: Bosch D/W SGV53E03GB/74 “Staining”
usually a sign of not enough water, pressure chamber/float blocked or blocked arms.
January 3, 2009 at 9:00 am #272786bzz67
ParticipantRe: Bosch D/W SGV53E03GB/74 “Staining”
if its mainly in one basket it could be a fault in the diverter on the heater assembly, im starting to see a lot of these going faulty.
January 3, 2009 at 12:56 pm #272787a1al
What does the diverter do and in what way does it go faulty
thanks for your reply bzz67
al
January 3, 2009 at 1:24 pm #272788bzz67
to reduce the amount of water needed to charge the system, a diverter, (small motorized disc with holes in it) is fitted. as the disc turns it sends water to one spray arm then the other. i have seen motor failure and worn gearing on these resulting in poor pressure to one or both spray arms depending on where the disc stops. biggest problem with this job is that the part only comes with heater assembly at around £100.00 retail, + the fitting time makes it very expensive.
January 3, 2009 at 3:21 pm #272789a1al
Thanks for that bzz67 I’ll Have to arrange another visit to take a look
Many thanks
January 6, 2009 at 2:32 pm #272790loopey
Iff its a diverter motor failure , put a fiver on it .. just unclip the motor replace with
indesit slave timer motor , much cheaper way of fixing it ….January 6, 2009 at 4:00 pm #272791Martin
loopey wrote:Iff its a diverter motor failure , put a fiver on it .. just unclip the motor replace with
indesit slave timer motor , much cheaper way of fixing it ….Now you must be joking there loopey? 😕
You mean to say you would go to all the trouble of dragging an expensive integrated machine out, take it to bits and then whap in a secondhand INDESIT TIMER MOTOR?8O 😯
I can’t figure it as most failings of this device are drive gearing and leaking water seals, the last thing to fail usually is the drive motor in my experience and I certainly wouldn’t fuff about with it having stripped it down that far….new water heater unit…sorted!!!! :rolls:
January 6, 2009 at 7:26 pm #272792BSH-MAN
:rotfl: :rolling:
