bosch d/w SHV55M03GB/56 leaking into sump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch d/w SHV55M03GB/56 leaking into sump
  • #60159
    senseib
    I have a customer complaining about his bosch d/w leaking. I just wondered if there was a most common cause why Bosch d/w leak into the sump? Did a search but didn’t find much.
    Brian.
    #340941
    don
    Re: bosch d/w leaking into sump
    ENR number will help please if you want to get a response to your enquiry 😉
    Don
    #340942
    senseib
    Re: bosch d/w SHV55M03GB/56 leaking into sump
    ENR SHV55M03GB/56
    #340943
    Criscold
    Check Pressure Chamber L/H Side + seals on wash pump and also pump to sump seal – check the pipe from sump to pressure chamber for blockage.
    #340944
    senseib wrote:I just wondered if there was a most common cause why Bosch d/w leak into the sump?
    1) Water inlet matrix/pressure switch unit overflow due to gunge blockage.
    2) Main circulation pump shaft seal leak.
    3) Salt container/tub seal gasket leak.
    4) Stainless tub rusted through (i.e tiny pin holes in bottom of tub adjacent fine mesh filter)
    5) Someone opening the door mid-cycle to take something out, heat/steam belches out, door shut, mass of water shoots up the vent hose into base!
    6) Inlet hose gasket leaking, dripping water into baseplate.
    7) Rodent damage.
    8] Overflow from gunged-up water inlet matrix (easy to suss, loads of brown shoose top left-hand corner, as it fills, water pi$$es out of the top!)
    9) Bottom door seal
    …and finally….
    10) Bottom spray arm not located properly as squirting in all directions!
    Hope that helps you pal?…. 😉
    #340945
    senseib
    Thanks for the replies:
    Hoping someone would just say yes probably just this! Life’s never that simple – I’ll take the check list with me 🙁
    Brian.
    #340946
    keithwilliams
    just take off both side panels and after removing water from the sump give it a quick run and keep your eyes open. then refer to martins list. the most awkward/expensive leak i had to fix was the seal on the heater box was perished but thats only one of countless dozens. chances are it will be a simple repair.
    #340947
    the most common, difficult to see, leak I have had on these are a leaking solonoid valve. Odd really as you rarely get them leaking on other appliances.
    Usual suspects are, as stated above.
