Bosch D/w SMS50EO2GB fault code reset
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch D/w SMS50EO2GB fault code reset
  • #42860
    fidder
    Hi to all
    Have a problem with new Bosch d/w…it had a drain problem..E14 and cut out. Have cleared the problem..blockage…but fault code comes up still. Is it holding on to fault and needs to be cleared? if so…any help to do this would be appreciated. Cheers Fidder
    Sorry missd off mod no.
    #275186
    nomadPaul
    E14 is not a drain error – its to do with the flow of water coming into the appliance.
    basically , the machine knows its got water in it but it isn’t detecting any water coming in i.e the flow rate meter isn’t sending any pulses to the board.
    I’d check water pressure is ok and failing that , i’d be looking at the flow sensor
