Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch d/w sms53e12gb/01 (about 4 years old)
- This topic has 20 replies, 7 voices, and was last updated 11 years, 7 months ago by
sce.
October 7, 2014 at 6:28 pm #418861
smeghead
ParticipantRe: bosch d/w sms53e12gb/01 (about 4 years old)
yep, that’s how I do it , mind you I’m suffering with sciatica at the mo ‘ so every job is taking a good bit longer than usual.
The freestanding is the same.October 7, 2014 at 6:38 pm #418862Andy jones
You have my sympathy. I’ve got tennis elbow in both flaming arms
The joys of being a service engineerSent from my iPad using Tapatalk HD
October 8, 2014 at 10:44 pm #418863nomadPaul
If its the heat pump you’re talking about you’re going about it the wrong way. No need to drop the base at all as it can be done from the side. Side panel off , module popped out the way. Disconnect 3 plugs from heat pump. Carefully cut away securing circlip on right hand side , take of bungee clip then twist pump clockwise before pulling towards you. Then fit in reverse remembering to fit the new jubilee clip in the right position and orientation.
October 8, 2014 at 11:55 pm #418864eastlmark
ModeratorRe: bosch d/w sms53e12gb/01 (about 4 years old)
smeghead wrote:
eastlmark wrote:
Why scrap? have you seen how cheap the pump is for those? (£62 from qualtex) and it includes the heater, formerly £90 odd in itself on previous Bosch dishwashers. Easy change too once you get the hang of it.easy to change! how long does it take then- total strip down job innit’, 2-2 1/2 hours ?
if there’s an easy way I wish I knew!
Clive.nomadPaul wrote:If its the heat pump you’re talking about you’re going about it the wrong way. No need to drop the base at all as it can be done from the side. Side panel off , module popped out the way. Disconnect 3 plugs from heat pump. Carefully cut away securing circlip on right hand side , take of bungee clip then twist pump clockwise before pulling towards you. Then fit in reverse remembering to fit the new jubilee clip in the right position and orientation.
what he said, done a few now 20 minutes tops for a freestanding.
October 9, 2014 at 2:23 pm #418865Andy jones
Will try that next time. Cheers
Sent from my iPad using Tapatalk HDOctober 9, 2014 at 5:36 pm #418866smeghead
Me too!
