Bosch D/W tap symbol
  • #74586
    Enr: SMV50E00GB/01
    Not been out to it yet, customer says tap symbol is flashing, has checked water pressure and filters which are fine.
    Does this model have an impellor jug, if not what are the usual suspects?
    timdowning
    Re: Bosch D/W tap symbol
    It will list it on bosch eshop if it has a jug or not.
    Could just be water in base due to blockages though.
    #392130
    Did have a look and couldn’t see one, just wanted to make sure.
    #392131
    wizard
    Jim, that’s one of the new ones that has a flow sensor (impellor jug) on the side tank, position 0405 on the parts diagram. Have changed a couple of these, although may be just a poor connection. Could also be water in the base – usual suspect for leaks is the connection between the side tank and tub (round plastic vent towards rear). I usually take tank off, clean o’ring and refit with a smear of silicon sealant. Wiz
    #392132
    Thanks, calling tomorrow, will update. 🙂
    Hmm,
    Only a teaspoon of water in the base, no real signs of leaks. Tightened up the contacts on the flow meter and ran on test.
    Everything appeared to work OK but I thought the fill was rather slow and he admitted turning the water pressure down for an unrelated problem.
    Turned it back up and it filled faster, so it’s suck it and see time. 🙂
