Bosch D/Washer error codes
  • #54449
    Jonah
    Hi all,
    Has anyone got a list of the error codes on Bosch dishwashers have tried searching but can’t find anything 😕
    #319647
    don
    Re: Bosch D/Washer error codes
    Morning Jonah
    From the known error codes if it helps 😉
    Martin wrote:(some)Bosch Loggixx Dishwasher codes
    Common error codes on models with LED display:-
    A or B = Aqua sensor fault.
    C = No tacho pulses (i.e Motor runs at full speed 2,800rpm).
    D = Short circuit triac to Circulation Pump (pump keeps running).
    E = Water points switching error between top & bottom basket.
    F = Filling error (time out 6 mins)
    G = Water points error, triac fault on circuit board, short circuit.
    H = Heating error (time out) Element, relay on module or pressure s/w.
    K = NTC error
    O = Safety level switching error
    No hard and fast rules apply to the above, but some knowledge is better than none I suppose? 😉
    Don
    ps Bosch washer dryer go in okay?
    #319648
    Jonah
    Cheers Don, yeah dryer went in ok she was very happy with it, got an error code of H03 so must be heater problem I guess !!!
    #319649
    gegsy
    Model number off appliance ?
    #319650
    Jonah
    Hi Gegsy,
    Model number is SGS47E02GB/56, haven’t been there yet but customer says it’s showing h03
    #319651
    gegsy
    Could possibly be e03 – water fill problem ??
    gegsy
    Most likely culprit is impeller jug/flow meter tbh 🙂
    Jonah
    Thanks Gegsy will update thread after I’ve been out to it 🙂
    #319654
    Jonah
    😆 Thanks Gegsy, spot on it was Impellor Jug faulty 😀
