Bosch SGS53C02GB/15 This is the one you can take the base off easily.
Keeps pumping and not starting programme, ( fault we got on older machines when base flooded)
Flout was greasy mess cleaned up and checked flout micro switch which was OK
Replaced flow meter. Still the same ?
Any ideas
I’m not sure why you went to the bother and expense in changing the anti flood? All you needed to do was take one tag off the micro switch in order to test it. 🙁
