Bosch Dish Washer SMS53A02GB/01Heat Pump
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dish Washer SMS53A02GB/01Heat Pump
  • #89725
    Landy813
    <a href="” target=”_blank” rel=”nofollow”>
    Hello all,
    I am trying to find out if my PCB is bust, as the machine just runs as normal without getting hot with no error codes. I am only getting 100 v to the Heat pump I have written the resistances i get across the element and what i think is the NTC sensor on the photo and they seem ok, i think?
    Should I be getting 230v at the heat pump or should i be looking else where for the fault?
    Any help much appreciated.
    Landy
    #442310
    Re: Bosch Dish Washer SMS53A02GB/01Heat Pump
    dont know the whole story with these but
    the heater will be the 2 red wires. bit worried about your resistance reading as with 18 ohms and a 230v supply give you a current of 12.7 amps which is too high. the other wires should feed the motor which is a 3 phase unit and may well work on 100 volts i dont know
    double check the heater continuity if ok its something else
    Landy813
    Just re-check it with a calibrated Fluke from work and it is defo 18.5 ohms.
    Landy
    #442312
    Landy813
    Just done some more checks, the voltage at the heat pump when connected is only 24v but when disconnected the voltage rises to 120v. So it could be a short across the element as both cables read 24v when connected to the pump.
    But surely the feed to the heater must be 230v?
    Landy
    #442313
    Landy813
    Well not to sure what i have done but it is now working again. I stripped the bottom and then stripped down the heat pump checked the control module for any obvious signs of damage then put it all back together. Then de-greased the condensation/fill assembly thing on the left hand side.
    Lets hope it keeps going!!!
    Landy
