Bosch Disheasher : E14 Error Code :
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Disheasher : E14 Error Code :
  • #92450
    Hanuman
    Getting an Error Message E14 on our Bosch Dishwasher …
    I have already read an Occasion here with same problem where a chip replacement did the trick.
    Where is the exact location of this plastic flap to access and replace the chip please ?
    Is there a sketch that can be seen please ?
    #451324
    Re: Bosch Disheasher : E14 Error Code :
    Bottom right hand side, directly behind where the main lead connects is the main power board you’re looking for presumably.
    #451325
    Hanuman
    Hi Martin sorry to ask again ..
    Any chance of a rough sketch please ?
    Do I have to actually remove the whole big plastic cover ?
    Sorry to bother you again
    Kris
    #451326
    Hanuman wrote:Any chance of a rough sketch please ?
    Sketch? What of?
    “Hanuman” wrote:Do I have to actually remove the whole big plastic cover?
    ??? Are you referring to the power module under the plastic cover? If so then yes of course. 😕
    #451327
    Hanuman
    Sorry Martin for the Confusion..
    I just want to access the water feed area where there is an Electronic Chip which controls the flow of water.
    I am getting an error code E14…
    One of the persons here had the same problem and was able to resolve this error code.
    I am not sure hence I asked you..
    Sorry again for the confusion.
    I hope you’ll understand this message now and may be able to help me get to this area..
    Thank you ..
    #451328
    You’re talking about the Reed Switch (not chip) that sits in the side of the water matrix. That is easily accessible by removing the left hand panel.
    #451329
    Hanuman
    Thank you so much Martin…
    Really appreciate your time ..
    I am going to attempt the repair soon ..
    Kind Regards
    Kris
    #451330
    Hanuman
    Hi Martin,
    I just removed the left panel of the Bosch Dishwasher.
    I know I have to remove the plastic cover to access the area where Reed Switch is by the water tank.
    I removed the two middle screws.
    Is it safe to pull out the cover now or is there any more ?
    #451331
    Hanuman wrote:Hi Martin,
