Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Dishwasher
- This topic has 6 replies, 4 voices, and was last updated 21 years, 7 months ago by
admin.
August 17, 2004 at 10:39 pm #6052
KeymasterHello,
My diswasher started giving me trouble after few years use now and today he decided that he is on strike..
When i press the On/Off swich it does not stay on.So if i keep it pressed it works but as soon as i release my finger it goes off.
Mddel is SM 65 and it is not electronic type.If u can suggest what should i do.
Called bosch they think the entire swichboard may need replacement costs £60 and anothe £50 for engineer….may be a new dish washer be a better idea…Thanks in Advance
August 17, 2004 at 10:55 pm #115337Penguin45
ParticipantHi GMK,
We’ll need a bit more to go on – SM65 is not the model number. Have a close look at the top off the inner door; you should find the model no. etched into the top surface.Some of these machines have a separate switch which is not too expensive, some are a combined “keyboard” which may be rather dear.
Bosch is a quality brand, for a failure as simple as this one it may well be worth having it repaired.
Bear in mind also that an independant repairer may well have a lower labour charge than sending for Bosch!
If you check in “Directories”, you might find a local UKW repairer, or put your post code up in here and somebody may well respond.
Penguin45.August 18, 2004 at 8:16 am #115338admin
KeymasterRe: Bosch Dishwasher
Checked the model number it is SMS 65
August 18, 2004 at 8:30 am #115339Martin
ParticipantRe: Bosch Dishwasher
GMK,
You are still a little economical with the model number BUT assuming it is actually a SMS6502GB/01 to /07 series it will need a complete Push Button Switch Unit (Part No:- 151864) at a cost of around £70, I believe?
August 18, 2004 at 8:34 am #115340Dave_Conway
Guest -Milton Keynes wrote:Checked the model number it is SMS 65
It’s still not long enough, it will be SMS65??GB/??
The nearest appears to be SMS6502GB/?? but there’s a few versions, all appear to have the same switch unit though, which is £63.87 inc VAT.
The labour rate you have been quoted is about right to be honest.
August 18, 2004 at 8:54 am #115341admin
The model number is SMS 6502GB/07
is it a DIY work…Unscrew the panel with * screwdriver.Takeout the swich and fit the new one…
Can it be another problem other than switch…may be i buy a switch and find out later that it was something else.Your help is appreciated…
August 18, 2004 at 1:08 pm #115342Dave_Conway
It will almost certainly be the switch unit, that you need.
Sorry, we are unable legally to advise on fitting the part.
